SDasa2
6 years agoDear Sir, just before 15 days we got ARRIA10GX development kit . 1.We connected bitec FMC HDMI connector RECEIVER sink to PC GPU GTX1050. and connected 4k tv to the transmitter side.
when we loaded the precompiled sof file to the kit --- in nvide control panel its detecting the arria10gx card. but there is no display on source -4K TV. we installed quartus prime 17.1 pro and the ...
- 6 years agoHi Sir, I installed quartus19.3 prime pro version and while generating the example design THE WARNING MESSAGE CAME ABOUT NIOS 2 SOFTWARE CAN NOT BUILT. image attached. HDMI Intel® FPGA IP User Guide Updated for Intel® Quartus® Prime Design Suite: 19.3 in this datasheet page no 4 : related information arria10 gx example design link shows the following information on first page HDMI Intel® Arria 10 FPGA IP Design Example User Guide Updated for Intel® Quartus® Prime Design Suite: 18.1.. *I generated design example in 19.3 AND COMPILED * *1. which quarus prime version i have to instal ?* *2. compilation time is 40 minutes . how can we reduce compilation time? * *after loading sof file sink detection is not there .*
BoonT_Intel
6 years agohi, I don't see any attachment. Can you please attach again. Also, based on your current description, it seem like completely different with what you reporting in the beginning. Please confirm what is the actual issue that you are facing now.
- SDasa26 years ago
Hi Sir, Our FAE is in contact with INTEL he raised a case, for the same kit. as per his suggestion as uhd design is complicated version he told to refer a design hdmi tx_rx retransmit i will attach data sheets . so i installed quartus 19.3 prime pro version and for this we have to install NIOS2 ide MANUALLY HENCE WHICH VERSION OF NIOS 2 I HAVE TO INSTALL? I CREATED THE EXAMPLE DESIGN AND LOADED THE SOF FILE . BUT ONE OF THE GRN LED "D8" LED IS BLINKING CONTINUOUSLY. IF I FOUND THE TX RX DATA PATH OK I HAVE SOME DOUBT ON MY DESIGN I WILL INFORM U ABOUT THAT. *Quartus Prime (includes Nios II EDS)* *Size:* 2.8 GB *MD5:* 7C1CDF9CEDCB81C730C5EC3BE15F6398 ** Nios II EDS on Windows requires Ubuntu 18.04 LTS on Windows Subsystem for Linux (WSL), which requires a manual installation. ** Nios II EDS requires you to install an Eclipse IDE manually. HENCE WHICH VERSION OF NIOS 2 I HAVE TO INSTALL? SO AS PER YOUR OPINION WHICH TOOL I HAVE TO INSTALL? PLS CLEAR MY PROBLEM AS IT IS VERY URGENT FOR OUT TESTING PURPOSE THANKS AND REGRDS d.suvarna- BoonT_Intel6 years ago
Hi Sir,
See the instruction from this link for the IDE installation
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/why-does-the-nios--ii-not-installed-after-full-installation-of-t.html
- SDasa26 years ago
Hi Sir, as per this links I installed nios2 _eclipse and crated example design again . - SDasa26 years ago
ATTACHED OTHER IMAGE RED MARK DURING COMPILATION .
