SDasa2
6 years agoDear Sir, just before 15 days we got ARRIA10GX development kit . 1.We connected bitec FMC HDMI connector RECEIVER sink to PC GPU GTX1050. and connected 4k tv to the transmitter side.
when we loaded the precompiled sof file to the kit --- in nvide control panel its detecting the arria10gx card. but there is no display on source -4K TV. we installed quartus prime 17.1 pro and the ...
- 6 years agoHi Sir, I installed quartus19.3 prime pro version and while generating the example design THE WARNING MESSAGE CAME ABOUT NIOS 2 SOFTWARE CAN NOT BUILT. image attached. HDMI Intel® FPGA IP User Guide Updated for Intel® Quartus® Prime Design Suite: 19.3 in this datasheet page no 4 : related information arria10 gx example design link shows the following information on first page HDMI Intel® Arria 10 FPGA IP Design Example User Guide Updated for Intel® Quartus® Prime Design Suite: 18.1.. *I generated design example in 19.3 AND COMPILED * *1. which quarus prime version i have to instal ?* *2. compilation time is 40 minutes . how can we reduce compilation time? * *after loading sof file sink detection is not there .*
BoonT_Intel
6 years agoHi Do you have chance to observe the LED status and try to change the resolution by pressing the button PB0,1 and 2?
As explained in Table 2 and 3 of the AN. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an776.pdf
- SDasa26 years ago
Hi, Sir, PROGRAMMED THE FPGA with master image file and when PB1 is pressed RED LED 7 is glowing. and when again pressed its not glowing. .From NIos2 command shell when running build_sw.sh fatal error . for files its telling permission denied.. and make failed condition arrived. ITS TELLING NO SIGNAL ON MONITOR . and display is blanking thanks and regards D.SUVARNA MIC ELECTRONICS LTD.
