mfortuna
6 months agoDDR4 Problem Migrating from Arria 10 016 to 048
We have a board design that supports an F29 package Arria 10. It has two DDR4 interfaces running at an 1866 data rate. In the past an 016 chip with DDR4-2400 ICs worked fine. We needed more logic s...
mfortuna
6 months agoI built the example design and it fails the same way. If I enable address/command leveling EMIF toolkit hangs. If I disable address/command leveling, the toolkit reports write-per-bit deskew failed.
The 016 based board works fine.
Another datapoint is the 048 works fine except for DDR4. The design has PCIe Gen3 x 8 and four 12.5G transceivers. The boards were designed with the upgrade from 016 to 048 in mind.
I did see another user had intermittent errors with an Arria 10 and DDR4-3200. But they were able to calibrate.
Address command leveling is pretty basic. write-per-bit deskew may be a red herring.
