matferronato
1 year agoDDR4 EMIF - Read without read valid
In my design, I instantiated and configured the EMIF IP via IP Catalog (not platform designer). I then correctly connected the signals according to design examples from Terasic. The flow of data fr...
AdzimZM_Altera
1 year agoHi,
Maybe you can check if the address is satisfied with the burstlength.
Try to get which address that start to have read issue by testing multiple times.
You also can verify if the EMIF IP setting is matching to the memory device datasheet.
Adzim
