senjd
4 years agoDDR4 controller arria 10 calibration issues.
In my arria 10 project, i am using ddr4 controller of intel ip with speed bins 1600 cl 12. After loading the bit file in to fpga, local_cal_success hits high. Which says that calibration passes. But w...
AdzimZM_Altera
4 years agoHi senjd,
I can check the EMIF IP setting in your design but I need the design or the EMIF IP file.
Are you able to share the design file?
If you cannot make it, then you can snapshot the IP configuration from the IP Parameter Editor GUI and post here.
Are you using your own custom board or Intel development kit?
You may provide the device OPN as well.
Adzim
