gyuunyuu
Contributor
7 years agoDDR3 does not seem to fit into MAX10 10M16
I have a "DDR3 SDRAM Controller with UniPHY Intel FPGA IP" instantiated on its own in a design with no other logic. When I compile the fitter is not able to place 8 pins. The error messages are in t...
Abe
7 years agoLooks like the Pin assignments are incompatible for the following pins:
RAM_BA0
RAM_BA1
RAM_BA2
RAM_CAS
RAM_RAS
RAM_CS1
RAM_WE
RAM_ODT
These pins which need 1.5V are being assigned to Banks which are already configured for 1.2V . Check the pin assignments and change them to the proper Banks for 1.5V and compile. This should solve the issue.
