gyuunyuu
Contributor
7 years agoDDR3 does not seem to fit into MAX10 10M16
I have a "DDR3 SDRAM Controller with UniPHY Intel FPGA IP" instantiated on its own in a design with no other logic. When I compile the fitter is not able to place 8 pins. The error messages are in t...
sstrell
7 years agoWhat is the memory configuration/setup? The EMIF spec estimator for MAX 10 with DDR3 only indicates you can use only a single chip select, but you have CS1 in these errors. Fill in your info here to see:
