SERMASWATHIKA
Contributor
2 years agoDDR3_CLK_DQS_SIGNALS_PIN_ASSIGNMENT
Hi team, I have tried to check the pin assignments with design files. I am getting error for DDR3 signals I/O Standard. Initially, I have configured the ddr3 I/Os with SSTL-15 CLASS I. when I ...
sstrell
2 years agoLooks like that pin cannot be used for DQ. Are you doing this in Pin Planner? Have you set the view for x8/x9 to highlight the pins supported for these functions?
SERMASWATHIKA
Contributor
2 years agoHi,
Yes, I am doing it in pin planner only with the highlights of DQ pins. i have assigned in dq pins only. I am sharing pin details sheet with this. can you please help me to resolve this?
do we need to connect rzq signal to ground?
FPGA DEVICE: 5CGXFC5C6F27C7
| To | Direction | Location | I/O Bank | VREF Group | Fitter Location | I/O Standard |
| cas_n | Output | PIN_A9 | 7A | B7A_N0 | PIN_A9 | SSTL-15 Class I |
| ck[1] | Output | PIN_H12 | 7A | B7A_N0 | PIN_H12 | Differential 1.5-V SSTL Class I |
| ck[0] | Output | PIN_G15 | 7A | B7A_N0 | PIN_G15 | Differential 1.5-V SSTL Class I |
| ck_n[1] | Output | PIN_G11 | 7A | B7A_N0 | PIN_G11 | Differential 1.5-V SSTL Class I |
| ck_n[0] | Output | PIN_G14 | 7A | B7A_N0 | PIN_G14 | Differential 1.5-V SSTL Class I |
| cke | Output | PIN_D21 | 7A | B7A_N0 | PIN_D21 | SSTL-15 Class I |
| cs_n | Output | PIN_A16 | 7A | B7A_N0 | PIN_A16 | SSTL-15 Class I |
| dm[3] | Output | PIN_B17 | 7A | B7A_N0 | PIN_B17 | SSTL-15 Class I |
| dm[2] | Output | PIN_A18 | 7A | B7A_N0 | PIN_A18 | SSTL-15 Class I |
| dm[1] | Output | PIN_C22 | 7A | B7A_N0 | PIN_C22 | SSTL-15 Class I |
| dm[0] | Output | PIN_C12 | 7A | B7A_N0 | PIN_C12 | SSTL-15 Class I |
| dq[31] | Bidir | PIN_D13 | 7A | B7A_N0 | PIN_D13 | SSTL-15 Class I |
| dq[30] | Bidir | PIN_D15 | 7A | B7A_N0 | PIN_D15 | SSTL-15 Class I |
| dq[29] | Bidir | PIN_A11 | 7A | B7A_N0 | PIN_A11 | SSTL-15 Class I |
| dq[28] | Bidir | PIN_C14 | 7A | B7A_N0 | PIN_C14 | SSTL-15 Class I |
| dq[27] | Bidir | PIN_D11 | 7A | B7A_N0 | PIN_D11 | SSTL-15 Class I |
| dq[26] | Bidir | PIN_C19 | 7A | B7A_N0 | PIN_C19 | SSTL-15 Class I |
| dq[25] | Bidir | PIN_C9 | 7A | B7A_N0 | PIN_C9 | SSTL-15 Class I |
| dq[24] | Bidir | PIN_C18 | 7A | B7A_N0 | PIN_C18 | SSTL-15 Class I |
| dq[23] | Bidir | PIN_C17 | 7A | B7A_N0 | PIN_C17 | SSTL-15 Class I |
| dq[22] | Bidir | PIN_D16 | 7A | B7A_N0 | PIN_D16 | SSTL-15 Class I |
| dq[21] | Bidir | PIN_E19 | 7A | B7A_N0 | PIN_E19 | SSTL-15 Class I |
| dq[20] | Bidir | PIN_C10 | 7A | B7A_N0 | PIN_C10 | SSTL-15 Class I |
| dq[19] | Bidir | PIN_M12 | 7A | B7A_N0 | PIN_M12 | SSTL-15 Class I |
| dq[18] | Bidir | PIN_N12 | 7A | B7A_N0 | PIN_N12 | SSTL-15 Class I |
| dq[17] | Bidir | PIN_C15 | 7A | B7A_N0 | PIN_C15 | SSTL-15 Class I |
| dq[16] | Bidir | PIN_C20 | 7A | B7A_N0 | PIN_C20 | SSTL-15 Class I |
| dq[15] | Bidir | PIN_B21 | 7A | B7A_N0 | PIN_B21 | SSTL-15 Class I |
| dq[14] | Bidir | PIN_A24 | 7A | B7A_N0 | PIN_A24 | SSTL-15 Class I |
| dq[13] | Bidir | PIN_B9 | 7A | B7A_N0 | PIN_B9 | SSTL-15 Class I |
| dq[12] | Bidir | PIN_E10 | 7A | B7A_N0 | PIN_E10 | SSTL-15 Class I |
| dq[11] | Bidir | PIN_B19 | 7A | B7A_N0 | PIN_B19 | SSTL-15 Class I |
| dq[10] | Bidir | PIN_F16 | 7A | B7A_N0 | PIN_F16 | SSTL-15 Class I |
| dq[9] | Bidir | PIN_E15 | 7A | B7A_N0 | PIN_E15 | SSTL-15 Class I |
| dq[8] | Bidir | PIN_A13 | 7A | B7A_N0 | PIN_A13 | SSTL-15 Class I |
| dq[7] | Bidir | PIN_A23 | 7A | B7A_N0 | PIN_A23 | SSTL-15 Class I |
| dq[6] | Bidir | PIN_G12 | 7A | B7A_N0 | PIN_G12 | SSTL-15 Class I |
| dq[5] | Bidir | PIN_B11 | 7A | B7A_N0 | PIN_B11 | SSTL-15 Class I |
| dq[4] | Bidir | PIN_B10 | 7A | B7A_N0 | PIN_B10 | SSTL-15 Class I |
| dq[3] | Bidir | PIN_A21 | 7A | B7A_N0 | PIN_A21 | SSTL-15 Class I |
| dq[2] | Bidir | PIN_A17 | 7A | B7A_N0 | PIN_A17 | SSTL-15 Class I |
| dq[1] | Bidir | PIN_A12 | 7A | B7A_N0 | PIN_A12 | SSTL-15 Class I |
| dq[0] | Bidir | PIN_A8 | 7A | B7A_N0 | PIN_A8 | SSTL-15 Class I |
| dqs[3] | Bidir | PIN_J12 | 7A | B7A_N0 | PIN_J12 | Differential 1.5-V SSTL Class I |
| dqs[2] | Bidir | PIN_L12 | 7A | B7A_N0 | PIN_L12 | Differential 1.5-V SSTL Class I |
| dqs[1] | Bidir | PIN_M11 | 7A | B7A_N0 | PIN_M11 | Differential 1.5-V SSTL Class I |
| dqs[0] | Bidir | PIN_H18 | 7A | B7A_N0 | PIN_H18 | Differential 1.5-V SSTL Class I |
| dqs_n[3] | Bidir | PIN_J11 | 7A | B7A_N0 | PIN_J11 | Differential 1.5-V SSTL Class I |
| dqs_n[2] | Bidir | PIN_K11 | 7A | B7A_N0 | PIN_K11 | Differential 1.5-V SSTL Class I |
| dqs_n[1] | Bidir | PIN_L11 | 7A | B7A_N0 | PIN_L11 | Differential 1.5-V SSTL Class I |
| dqs_n[0] | Bidir | PIN_H17 | 7A | B7A_N0 | PIN_H17 | Differential 1.5-V SSTL Class I |
| odt | Output | PIN_E11 | 7A | B7A_N0 | PIN_E11 | SSTL-15 Class I |
| ras_n | Output | PIN_B20 | 7A | B7A_N0 | PIN_B20 | SSTL-15 Class I |
