SERMASWATHIKA
Contributor
2 years agoDDR3_CLK_DQS_SIGNALS_PIN_ASSIGNMENT
Hi team, I have tried to check the pin assignments with design files. I am getting error for DDR3 signals I/O Standard. Initially, I have configured the ddr3 I/Os with SSTL-15 CLASS I. when I ...
sstrell
2 years agoLooks like that pin cannot be used for DQ. Are you doing this in Pin Planner? Have you set the view for x8/x9 to highlight the pins supported for these functions?
- SERMASWATHIKA2 years ago
Contributor
Yes, I am doing it in pin planner only with the highlights of DQ pins. i have assigned in dq pins only. I am sharing pin details sheet with this. can you please help me to resolve this?
do we need to connect rzq signal to ground?
FPGA DEVICE: 5CGXFC5C6F27C7
To Direction Location I/O Bank VREF Group Fitter Location I/O Standard cas_n Output PIN_A9 7A B7A_N0 PIN_A9 SSTL-15 Class I ck[1] Output PIN_H12 7A B7A_N0 PIN_H12 Differential 1.5-V SSTL Class I ck[0] Output PIN_G15 7A B7A_N0 PIN_G15 Differential 1.5-V SSTL Class I ck_n[1] Output PIN_G11 7A B7A_N0 PIN_G11 Differential 1.5-V SSTL Class I ck_n[0] Output PIN_G14 7A B7A_N0 PIN_G14 Differential 1.5-V SSTL Class I cke Output PIN_D21 7A B7A_N0 PIN_D21 SSTL-15 Class I cs_n Output PIN_A16 7A B7A_N0 PIN_A16 SSTL-15 Class I dm[3] Output PIN_B17 7A B7A_N0 PIN_B17 SSTL-15 Class I dm[2] Output PIN_A18 7A B7A_N0 PIN_A18 SSTL-15 Class I dm[1] Output PIN_C22 7A B7A_N0 PIN_C22 SSTL-15 Class I dm[0] Output PIN_C12 7A B7A_N0 PIN_C12 SSTL-15 Class I dq[31] Bidir PIN_D13 7A B7A_N0 PIN_D13 SSTL-15 Class I dq[30] Bidir PIN_D15 7A B7A_N0 PIN_D15 SSTL-15 Class I dq[29] Bidir PIN_A11 7A B7A_N0 PIN_A11 SSTL-15 Class I dq[28] Bidir PIN_C14 7A B7A_N0 PIN_C14 SSTL-15 Class I dq[27] Bidir PIN_D11 7A B7A_N0 PIN_D11 SSTL-15 Class I dq[26] Bidir PIN_C19 7A B7A_N0 PIN_C19 SSTL-15 Class I dq[25] Bidir PIN_C9 7A B7A_N0 PIN_C9 SSTL-15 Class I dq[24] Bidir PIN_C18 7A B7A_N0 PIN_C18 SSTL-15 Class I dq[23] Bidir PIN_C17 7A B7A_N0 PIN_C17 SSTL-15 Class I dq[22] Bidir PIN_D16 7A B7A_N0 PIN_D16 SSTL-15 Class I dq[21] Bidir PIN_E19 7A B7A_N0 PIN_E19 SSTL-15 Class I dq[20] Bidir PIN_C10 7A B7A_N0 PIN_C10 SSTL-15 Class I dq[19] Bidir PIN_M12 7A B7A_N0 PIN_M12 SSTL-15 Class I dq[18] Bidir PIN_N12 7A B7A_N0 PIN_N12 SSTL-15 Class I dq[17] Bidir PIN_C15 7A B7A_N0 PIN_C15 SSTL-15 Class I dq[16] Bidir PIN_C20 7A B7A_N0 PIN_C20 SSTL-15 Class I dq[15] Bidir PIN_B21 7A B7A_N0 PIN_B21 SSTL-15 Class I dq[14] Bidir PIN_A24 7A B7A_N0 PIN_A24 SSTL-15 Class I dq[13] Bidir PIN_B9 7A B7A_N0 PIN_B9 SSTL-15 Class I dq[12] Bidir PIN_E10 7A B7A_N0 PIN_E10 SSTL-15 Class I dq[11] Bidir PIN_B19 7A B7A_N0 PIN_B19 SSTL-15 Class I dq[10] Bidir PIN_F16 7A B7A_N0 PIN_F16 SSTL-15 Class I dq[9] Bidir PIN_E15 7A B7A_N0 PIN_E15 SSTL-15 Class I dq[8] Bidir PIN_A13 7A B7A_N0 PIN_A13 SSTL-15 Class I dq[7] Bidir PIN_A23 7A B7A_N0 PIN_A23 SSTL-15 Class I dq[6] Bidir PIN_G12 7A B7A_N0 PIN_G12 SSTL-15 Class I dq[5] Bidir PIN_B11 7A B7A_N0 PIN_B11 SSTL-15 Class I dq[4] Bidir PIN_B10 7A B7A_N0 PIN_B10 SSTL-15 Class I dq[3] Bidir PIN_A21 7A B7A_N0 PIN_A21 SSTL-15 Class I dq[2] Bidir PIN_A17 7A B7A_N0 PIN_A17 SSTL-15 Class I dq[1] Bidir PIN_A12 7A B7A_N0 PIN_A12 SSTL-15 Class I dq[0] Bidir PIN_A8 7A B7A_N0 PIN_A8 SSTL-15 Class I dqs[3] Bidir PIN_J12 7A B7A_N0 PIN_J12 Differential 1.5-V SSTL Class I dqs[2] Bidir PIN_L12 7A B7A_N0 PIN_L12 Differential 1.5-V SSTL Class I dqs[1] Bidir PIN_M11 7A B7A_N0 PIN_M11 Differential 1.5-V SSTL Class I dqs[0] Bidir PIN_H18 7A B7A_N0 PIN_H18 Differential 1.5-V SSTL Class I dqs_n[3] Bidir PIN_J11 7A B7A_N0 PIN_J11 Differential 1.5-V SSTL Class I dqs_n[2] Bidir PIN_K11 7A B7A_N0 PIN_K11 Differential 1.5-V SSTL Class I dqs_n[1] Bidir PIN_L11 7A B7A_N0 PIN_L11 Differential 1.5-V SSTL Class I dqs_n[0] Bidir PIN_H17 7A B7A_N0 PIN_H17 Differential 1.5-V SSTL Class I odt Output PIN_E11 7A B7A_N0 PIN_E11 SSTL-15 Class I ras_n Output PIN_B20 7A B7A_N0 PIN_B20 SSTL-15 Class I
