16 years agoDDR2 HP core pins plan problem!!!!
I used stratix II ep2s60f1020c5 , I want assigned the ddr II sdram pins to bank 8 and assigned the ddr II different clkp , clkn to bank 12 .Bank 12 is a pll bank . I must assigned VCCIO8...
16 years agooh,sorry. that is my careless, I used bank10 .
"Banks 9 through 12 are enhanced PLL external clock output banks. These PLL banks utilize the adjacent VREF group when voltage-referenced standards are implemented. For example, if an SSTL input is implemented in PLL bank 10, the voltage level at VREFB7 is the reference voltage level for the SSTL input." But I used bank 7 as 3.3_LVTTL. Is this design ok? thank you !!!
