18 years agoDDR2 High Performance Con V7.1 SDC file difference between Stratix III and Stratix II
Hi I create a DDR2 High Performance Controller V7.1 with a stratix II device and find that the auto-generated SDC file include many constraints, such as DQ/DQS/Addr/Cmd output delay, DQ input d...
18 years ago --- Quote Start --- Hi I create a DDR2 High Performance Controller V7.1 with a stratix II device and find that the auto-generated SDC file include many constraints, such as DQ/DQS/Addr/Cmd output delay, DQ input delay, clock max delay, false path,etc. But When I create the same controller with a stratix III device, the auto-generated SDC file doesn't include DQ/DQS output delay, DQ input delay, clock max delay. It only includes Addr/Cmd output delay and less false paths. I have two questions: 1. Why there are so many differences between stratix II and stratix III? 2. Should I add the DQ/DQS output delay and DQ input delay and the others into SDC file when I use TimeQuest to analyze timing with DDR2 High Performance Controller in stratix III? If someone knows about it, please tell me. Thanks --- Quote End --- HI shsong , can you provide your ddr2 controller sdc file for reference? regards --sampath
