kwkprd
3 years agoDDR Timing violations
Timing violation in task:- Report DDR timing analyzer
setup hold Address/Command (Fast 900mV 0C Model) | 0.18 0.18 Core (Fast 900mV 0C Model) | 1.391 0.012 Core Recovery/Removal (Fast ...
AdzimZM_Altera
3 years agoHello,
I have replicated the issue at my end and I can see the Read Capture timing violation with your EMIF IP setting.
I may suggest to use faster memory component that compatible with your memory device.
From my end, I have used memory speed bin -3200 parameter setting and running at 1066.667MHz clock frequency.
The timing is clean after running the compilation.
I hope you can get a same result as well.
Adzim
