14 years agoDDR-2 IP data error
Hi All,
We are working on DDR2-IP on two different Altera cyclone III EP3C120F780C7N development kit 1st-kit, called as A-kit The DDR(Micron) part number: combination of 8LD42-D9GMG and 8FB41-D90PN 2nd-kit, called as B-kit The DDR(Micron) part number: combination of 8YF12-D9JLR and 8EB41-D9DPN The data write and read are working good with the A-kit where as there is data corruption on some addresses while working on B-kit. We used the signal tap to check DDR-2 protocol, the protocol seems to be non-violated. Can anyone experienced the some similar problem, please do send the response on how we can handle this case. Thanks and Regards, Vijay K1 Reply
Timings are ok? What's the max freq of each chip? What's the controller freq?
