DCFIFO not empty but rdusedw=0 ?! (Agilex)
- 4 years ago
I'm just going by what I think is the most recent version of the guide:
https://www.intel.com/content/www/us/en/docs/programmable/683522/18-0/fifo-user-guide.html
Looking through it, I see the add_usedw_msb_bit option, which might be what you're looking for to see the correct value on rdusedw and wrusedw.
I don't know why the read side is showing empty when wrfull indicates it's full (which is strange), but check out the latest version of the guide and see if that helps. You're looking at a 12 year old version of the doc.
Thank you for your answer.
and less than or equal to 32 I set lpm_numwords value to 32. You agree that I did nothing out of specs, thank you for the confirmation.
Coming back to my question: how a 5b word can represent the number 32? (as you also wrote, 32 is a correct value for lpm_numwords and lpm_widthu=5)
Without even debating that, does everybody consider acceptable to see a fifo full and non-empty with no word inserted (or at least the counter showing 0)? In the steady-state after 10s of clocks to have the *usedwd stable and respecting the specs.
