mengyaozhu's avatar
mengyaozhu
3 years ago
cyclone xcvr 10g phy
测试cyclone10 10G transerver phy ip时,10gbase-r
求解:
tx_parallel_data 信号,fb控制信号可以在64bit 任意byte位置上么 ,仿真时 只能在tx_control=01的
字节位置上。
  • ZiYing_Intel's avatar
    ZiYing_Intel
    Can share your .qar file here? So that I can try debug the issue from my side.
    zying
    ZiYing_Intel
    zying
    ZiYing_Intel
    For your information, the width of tx_parallel_data and tx_control depends on whether the simplified interface is enabled or not. If the simplified interface is enabled, then tx_parallel_data = 64 bits and tx_control = 3 bits. The value 2'b01 indicates a data word and the value 2'b10 indicates a control word.
    zying
    ZiYing_Intel
    Since no hear any feedback from you, I am now close the case. If you have any question after the case closed, please do feel free to submit another issue.
    zying
