mengyaozhu
3 years agocyclone xcvr 10g phy
测试cyclone10 10G transerver phy ip时,10gbase-r 求解: tx_parallel_data 信号,fb控制信号可以在64bit 任意byte位置上么 ,仿真时 只能在tx_control=01的 字节位置上。
ZiYing_Intel
2 years agoHi,
For your information, the width of tx_parallel_data and tx_control depends on whether the simplified interface is enabled or not. If the simplified interface is enabled, then tx_parallel_data = 64 bits and tx_control = 3 bits. The value 2'b01 indicates a data word and the value 2'b10 indicates a control word.
zying
