BAbbott's avatar
BAbbott
5 years ago
Cyclone V SX - dual 10Gbe XAUI
I'm looking into implementing a dual XAUI interface for 10Gbe ethernet using the XAUI IP in a Cylcone V SX (5CSXFC5). I've been able to implement one, but I'm having issues implementing two. Theoritically, is it possible to implement two using the 9 GXB transceivers (Lanes 0-3 and Lanes 5-8) or do I need to go a different route?
It also looks as though 10Gbe is the only option - should I be using the 156Mhz reference clock for the REFCLK pins for this implementation or can they run to global clock input pins?
  • SengKok_L_Intel's avatar
    SengKok_L_Intel
    Besides, you have to use the 156.25Mhz as the input reference clock frequency for the XAUI.
    • BAbbott's avatar
      BAbbott
      So using CH4 for the input PLL + CH5-8 as the interface should be sufficient with REF_CLK0 being the input for the 156.25MHz?
      Making sure I understand that correctly.
    SengKok_L_Intel
    This is suggested to compile with a simple design to see if the Quartus allow this kind of combination to fit and whether there is any critical warning.
    SengKok_L_Intel
    If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
