Click_Er
7 years agoCyclone V GX Transceiver setup
I'm putting together a 2 channel transceiver design on a cyclone V GX device. This device has 3 channels. I want to use channel 1 and 3 since the custom board has already been designed and wired to t...
CheepinC_altera
7 years agoHi,
You can try to enable "Use external TX PLL" option in your Native PHYs. Then instantiate one CV Transceiver PLL IP and connect to the ext_pll_clk ports of the two Native PHY IPs.
Please let me know if there is any concern. Thank you very much.
Chee Pin
