Click_Er
7 years agoCyclone V GX Transceiver setup
I'm putting together a 2 channel transceiver design on a cyclone V GX device. This device has 3 channels. I want to use channel 1 and 3 since the custom board has already been designed and wired to t...
Click_Er
7 years agoI'm using Cyclone V XCVR Native PHY (altera_xcvr_native_cv). It's configured as x1 bonding with 1 data channel. PLL type is set to CMU with x1 clock network. I'm not sure how to do TX PLL merging. In fact I'm assuming that this is my problem. I have 2 instances of this IP in my design.
I also have an instance of altera_xcvr_reset_control. This IP is configured to reset 2 xcvr channels and 2 TX PLLs.
And lastly I also have an instance of alt_xcvr_reconfig. Number of reconfiguration interface is set to 2 and I've set grouping to 1,1.
