Cyclone V CAN triple sampling
- 3 months ago
Hi prmartinuk
The Cyclone V do not have the CAN Triple sampling.
There is no option to change the sampling rate of the CAN in the HPS.
You could find other register setting for the CAN in the Cyclone V HPS Register Map in the link below:
tehjingy
I cannot presently point to a Cyclone V HPS register definition or document explicitly proving triple sampling is implemented/enabled in Cyclone V HPS CAN. I will further check internally.
Have you tried "$ ip -details link show can0"?
If the Linux driver exposes: triple-sampling on/off
then the underlying controller/driver combination should support it.
- prmartinuk3 months ago
Unfortunately we aren't running Linux on our Cyclone V devices, so I can't quickly check via the driver.
I'll try to find the evaluation boards we got over 10 years ago and try to get Linux running on them.- tehjingy_Altera3 months ago
Hi prmartinuk
tehjingy
