10 years agoCyclone V - major transceiver misunderstanding
Hi all, I'm struggling with my understanding about Cyclone V transceivers in SX/GX devices. We have a custom board with 2 Cyclone V FPGAs. The one is an SX and the other one a GX device. ...
10 years agoMaybe to claryfy alittle bit why I'm so confused: This thread
http://www.alteraforum.com/forum/showthread.php?t=41766&highlight=transceiver (http://www.alteraforum.com/forum/showthread.php?t=41766&highlight=transceiver) mentions that there has to be done some word alignment in the HDL of my component which I just cannot believe .... but it seems as if that is the experience of some users. Additionally, it mentions that the simulation is working as expected but not the hardware..... That is why I try to get it working using signal tap (or at least gain some experience). Yesterday, I was able to actually see (by signal tapping the transceiver toolkit design an using loopback mode on the SX FPGA) that the PRBS7 pattern which I send on the TX side indeed gets received on the RX side. What I still wonder is this: I start sending the test pattern by clicking on start in the Transceiver Toolkit GUI (in the "transceiver link" tab, because I would like to use the serial loopback mode). I provided the synchronisation_question screenshot, where it is shown, when the transmission of a PRBS7 code is started. The first word send of this code is 0x020C28F22C. I triggered on that sequence on the RX Avalon ST input of the pattern checker component. It first appears after about 180 (blue questionmark) data words of useless(???) data. So I wonder, why is there so much useless data at the beginning on the RX side? Is it because the clock recovery of the RX PHY has to gather enough information in order to determine the correct clock for data de-serialization? The next thing is that after the first occurance of the PRBS7 data start word, there is still a huge gap without the data beeing vaild (asi_valid -> low, green questionmark). I know from other signal tap shots, that the asi_valid signal becomes valid after some time and therefor, I suppose I do not have errors on my transmission line in the Transceiver Toolkit. And after that I know, it is working very well, because I never see any errors even after hours..... I really just wonder, why it takes so long to get this asi_valid signal active? Is this a fixed time? Depending on what? What if I don't want to use this transceiver link to constantly send a stream of data but e.g. just 256 32 bit words every ms. I just want that to be very quick (and therefore use the transceiver link). But when I have to wait for so many clock cycles to get that asi_valid signal active, how can I know on the transmit side, that my data actually reached the destination? I know, I could use a very complicated protocol for that that detects packet loss, etc. But what would be the simplest method to do so? I just need a communication between the FPGAs as described above: every ms I would like to transmit a certain amount of data. I would like the data to be correctly received from the very first word on (not like in the screenshot example above). I think , I have to constantly transmit some kind of IDLE pattern like 0x55555555 and, when my user data should be send just put that into the stream instead of the IDLE pattern, right? Is this the way to go? Okay, I will wait for (hopefully) some answers on that in order to discuss this further if somebody is willing to help me improve my understanding. Thanks, Maik
