Cyclone IV GX project failed migration from 20.1 to 23.1std
Hi Jarbugeri,
Is there any error code shown in Quartus?
Can you please provide me the Error code ? or a print screen will help me to better understand the problem.
Wincent_Intel
- Wincent_Altera2 years ago
Hi Jarbugeri,
Sorry I miss your detail in the case description.
From the error "Error: altgx_internal: error renaming "C:/intelfpga_lite/23.1std/quartus/../ip/altera/altera_pcie/altera_pcie_avmm/lib/altpcie_serdes_3cgx_x1d_gen1_08p.v.new" to "C:/intelfpga_lite/23.1std/quartus/../ip/altera/altera_pcie/altera_pcie_avmm/lib/altpcie_serdes_3cgx_x1d_gen1_08p.v": best guess at reason: permission denied"It seems like your altpcie_serdes_3cgx_x1d_gen1_08p.v.new is somehow missing.
The error can be due to a myriad of reasons and might be difficult to pinpoint exactly. However, I've laid out some suggestions to help we narrow this down further and confirm the error.- Try running Quartus Prime as an administrator. Right-click on the Quartus Prime shortcut or executable and select "Run as administrator." This ensures that Quartus Prime has the necessary permissions to perform file operations.
- Try moving your Quartus project to a location with a shorter path, avoiding spaces or special characters in the directory names. Sometimes, long or complex paths can cause issues with file operations.
- Copy the file from your previous Quartus version (working) to the one you migrate to.
Let me know if this solved your problem.
Regards,Wincent_Intel
- Jarbugeri2 years ago
Hi Wincent.
1 - Dont Work for me.
2 - Dont work.
3- What files specifically should I copy?
Regards,Jarbugeri
Hi Jarbugeri,
based on the error code, it should be some file call altpcie_serdes_3cgx_x1d_gen1_08p.v
