Cyclone IV GX PCIe Hard IP behaves differently on Intel Core I7 vs Xeon root complexes
Hi SharmaUmesh278 ,
Are repeated accesses to BAR-space offsets after boot expected from BIOS/UEFI, Windows PCI bus enumeration, or other background PCIe activity?
>> In our user guide mentioned that, the RX logic processes requests from the root complex, and that the Avalon-MM RX master issues the corresponding Avalon-MM read/write transactions into the FPGA fabric. It also states that some bridge register regions are typically intended for access by PCI Express processors only, and that the PCI Express root complex typically requires write/read access to certain mailbox registers. So the guide supports the idea that root-complex-originated accesses are normal
>> detail please refer to IP Compiler for PCI Express User Guide
Has anyone observed different behavior between Intel Core desktop root complexes and Xeon/server root complexes when using the Cyclone IV GX PCIe Hard IP?
>> Our PCIe IP is following PCI-SIG compliance
>> As long as the Laptop is PCI-SIG compliance, by right it shall be no problem.
>> But in your case, I would suggest to switch to another different host and check if the error is follow. I suspect is individual host issue.
Are there known interoperability issues between older Cyclone IV GX PCIe endpoints and modern Gen3/Gen4 server root complexes, even when the link successfully negotiates to Gen1 x1?
>> Are you using Gen1 design if I understand correctly ?
>> I would suggest to set the BIOS PCIe speed from "auto" into "gen1", I did experience certain brand of host actually cannot perform auto negotiation.
Is there a recommended way to distinguish firmware/OS-generated PCIe accesses from accesses generated by the application or function driver?
>>From what I understand , the RX block processes requests from the root complex, passes header information to the Avalon-MM master, and the RX master generates the corresponding Avalon-MM transactions to the connected slaves.
Wincent_Altera
a { text-decoration: none; color: #464feb; } tr th, tr td { border: 1px solid #e6e6e6; } tr th { background-color: #f5f5f5; }
Hi Wincent_Altera,
Let me clarify my observation.
When a PCIe read or write transaction occurs, SignalTap captures the transaction correctly and I can see the expected activity and data values.
However, only for a short period after the transaction. A few moments later, the observed data bus returns to 0xFFFFFFFF (all bits = 1) again.
In other words, the correct value is visible only while the transaction is active and captured by SignalTap. After that, the signal returns to its default state of all 1's.
Because of this, it appears that the driver is reading 0xFFFFFFFF, while SignalTap shows the expected value during the actual transaction.
Is 0xFFFFFFFF the expected idle/default value on the Avalon-MM read data interface when no valid read response is present, or could this indicate a completion/read response issue?
I have already forced the PCIe link speed to Gen1 and confirmed successful Gen1 x1 link negotiation. The behavior remains the same.
Could you also let me know which PCIe driver/test application is used for Cyclone IV GX PCIe validation?
Umesh Sharma
- Wincent_Altera2 months ago
Hi SharmaUmesh278 ,
Can you please try out below design https://docs.altera.com/r/docs/683541/current/an-456-pci-express-high-performance-reference-design/software-requirements
You can download via PCI Express High-Performance Reference Design in Cyclone IV GX DevicesIf SignalTap shows correct data only during the valid window, your main problem is probably handshake/timing at the AVMM read interface, not the idle 0xFFFFFFFF itself.
Wincent_Altera - Wincent_Altera2 months ago
Is there anything else I can better assist you ?
Regards,Wincent_Altera
- SharmaUmesh2782 months ago
Hi Wincent_Altera ,
Thank you for the support.As we have put the project on hold, I will not need further assistance for now. I think the problem might be on my driver side, so I have currently decided to stick with the Intel Core CPU where it works.
I may contact you again in the future when we resume.
Thanks a lot!
Umesh Sharma
Hi SharmaUmesh278 ,
Thanks for your response, you are most welcome, do file a new thread whenever you need any help.
We will be there for you. Looking forward to see you again in the future.
Wincent_Altera
