manu-solystic
3 years agoCyclone 10GX PCI express without clk_user any solution ?
I have a prototype design with a Cyclone 10GX
I want to use the PCI express , but the clk_user is not connected And if i read the documentation about the PCI express with cyclone 10Gx , this clock...
- 3 years ago
So I understand that the only solution is to connect a clock on the clkuser pin
So you can close this ticket
regards
Wincent_Altera
3 years agoHi,
We wouldn't advise turning off the CLKUSR clock. In my view the FPGA device won't be expecting this to happen.
The CYclone 10 PCG states on page 19 :
- This pin is used as the clock for transceiver calibration, and is a mandatory requirement when using transceivers.
- This pin is optionally used for EMIF HMC calibration, as well as a configuration clock input for synchronizing the initialization of more than one device.
- This is a user-supplied clock and the input frequency range must be in the range from 100 MHz to 125 MHz.
- https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/dp/cyclone-10/pcg-01022.pdf
Hope this clarified,
Wincent_Intel
