manu-solystic
3 years agoCyclone 10GX PCI express without clk_user any solution ?
I have a prototype design with a Cyclone 10GX
I want to use the PCI express , but the clk_user is not connected And if i read the documentation about the PCI express with cyclone 10Gx , this clock...
- 3 years ago
So I understand that the only solution is to connect a clock on the clkuser pin
So you can close this ticket
regards
Wincent_Altera
3 years agoHi,
Also there is an extra notes for your information in
https://www.intel.com/content/www/us/en/docs/programmable/683417/current/transceiver-pins.html
Other than those two pins, I don't see any alternative pin to perform it.
Also, Intel does not test on the function of other pins that can perform a similar function in any historical test.
Wincent_Intel
