manu-solystic
3 years agoCyclone 10GX PCI express without clk_user any solution ?
I have a prototype design with a Cyclone 10GX
I want to use the PCI express , but the clk_user is not connected And if i read the documentation about the PCI express with cyclone 10Gx , this clock...
- 3 years ago
So I understand that the only solution is to connect a clock on the clkuser pin
So you can close this ticket
regards
FvM
3 years agoPin connection guidelines clearly state:
"This pin is used as the clock for transceiver calibration, and is a mandatory requirement when using transceivers".
- manu-solystic3 years ago
So Thanks
So i saw this item, but too late, on my board, this pin is not connected,
So i Ask here , if there is a way to route another clock to this signalsIf I can check the PCI express, on my board, without this pin
We plan to reroute this board, with this clock connected,
but what i want is to check the PCI express on my prototype board
regards
