Michael2021
5 years agoCyclone 10 GX DisplayPort Rx
Hello dlim,
I modified the custom Dipalyport Receiver board. The Modified point is CLKUSR pin only
DisplayPort Receiver function still doesn't work.
I attached two picture.
Picture 1 : cy...
Deshi_Intel
5 years agoHi,
Yup, Intel FPGA C10 GX dev kit board comes together with schematic and board layout file which should serve as good reference for your board design.
Regarding the control of repeater chip,
- I am sorry I don't have any doc for it as it's not Intel chip
- Reg configuration of repeater chip should be via DP example design NIOS software I2C bus design, not via DPCD but it's meaningless unless you download the the repeater datasheet to understand the repeater chip reg function
dlim
