Michael2021
5 years agoCyclone 10 GX DisplayPort Rx
Hello dlim,
I modified the custom Dipalyport Receiver board. The Modified point is CLKUSR pin only
DisplayPort Receiver function still doesn't work.
I attached two picture.
Picture 1 : cy...
Michael2021
5 years agoHello dlim,
I attached two picture and rx_analogreset, rx_digitalreset and rx_is_lockedtodata signal look good.
But still PC generate link failure (attached pic).
I think the failure is in DisplayPort link training sequence. I looked rx_reconfig read/write signal group and rx_link_rate_8bit appeared "14h, 0Ah, 06h. so PHY reconfiguration looks good.
Can you provide more information of DisplayPort link training sequence and aux channel access command to analyze problem ?
Any other check point do I need ?
Michael
