Cyclone 10 GX DisplayPort Rx
Hello dlim,
I attached two picture, it is for previous mail.
I captured all reconfiguration interface address and data. It looks correct.
The read and write operation repeated each channel but I captured only one channel.
I think the CDR pll doesn't lock. I checked 135MHZ clock. it is ok
Michael
Attached is the C10 CDR loose lock debug check list for your reference
- Deshi_Intel5 years ago
ok, looks like transceiver calibration can be completed and it's not stuck in reset mode anymore
I have 2 suggestion for you. You should isolate whether the CDR loose lock issue is caused by your board issue or your Quartus design issue.
To rule out potential board issue :
- Perform FPGA transceiver channel internal loopback follow by external loopback on board
- FPGA transceiver channel internal loopback must works else there is really some issue with your board or the FPGA device itself or some manufacturing soldering contact issue
- You can perform internal loopback using transceiver toolkit. Reference design and user guide doc is available in below link
- https://fpgacloud.intel.com/devstore/platform/17.1.1/Pro/cyclone-10-gx-xcvr-toolkit-reference-design/
- Once you verified to get the internal loopback working, then you can move on to check with external loopback on your board. (assuming you can perform external loopback on your board)
- If it's failing with external loopback, then you can cross check the debug suggestion in CDR debug checklist that I shared with you in previous post
To rule out potential Quartus design issue
- It would be best if you can just stick with using DisplayPort Rx to Tx example design to bring up the DP Rx first before you move on to make design modification on it
dlim
- Michael20215 years ago
Hi dlim,
I installed C10GX_toolkit_demo design kit and I got same result as mine.
I probed internal signal as below
pll_locked : always "L" : means doesn't locked
locked : always " L" : this signal is IOPLL lock signal for test. but the 16MHZ clock comes out
rx_is_lockedtodata : always "L" : same result as my design
I attached C10GX_toolkit_demo design and Board schematic (power portion)
I think my board has a problem in PLL function and Power connection is correct or not (?)
Can you review where is wrong connection ?
Thank you
Michael
Hi Michael,
I am not power expert but I do noticed 2 main concern that alert me.
- FPGA RREF pins (Reference resistor for fPLL, IOPLL, and transceiver) is not connected to 2Kohm Resistor then to GND. Highly suspect PLL functionality failure is caused by RREF pins connection.
- FPGA Vref power supply pins : You may need to power up Vref pins depends on input IO pins usage (depends on IO standard)
It's very dangerous if there is still issue with your board design. I strongly recommend you to perform full board schematic review again. Below is one good reference doc that can help you on board schematic review
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-10/pcg-01022.pdf
dlim
