jlats2
4 years agoCyclone 10 GX ASMI Parallel IP debug
I am attempting to implement the ASMI Parallel IP on my Cyclone 10 GX. I am able to perform sector erases and reads just fine (I can erase everything and read back all FF's). However when I...
- 4 years ago
Responding to myself for the benefit of future readers:
Do not leave the pin high. Strobe en4b_addr once, possibly during your boot up process, and keep it low.
If you have en4b_addr HI when you attempt to perform a shift, the en4b_addr command appears to be set in preference over shift operations.
NurAiman_M_Intel
4 years agoHi,
Apologize for the delay in response as I just receive notification today.
Thank you for sharing with us your answer. If this case has been solved, I will proceed to close this ticket.
Aiman
- jlats24 years ago
No worries, thank you for your response.
