RicardoC
3 years agoCXL IP DVSEC
Is the PCIe DVSEC registers for CXL Device implemented either in the R-Tile CXL HIP or in the Soft Wrapper? If not, is there an Intel IP that can be attached to the CXL.IO port that can provide...
RicardoC
3 years agoHi,
Instantiating the Intel R-Tile for Compute Express Link IP in Platform Designer gives me an option to choose the CXL Function Mode as:
-Full TLP Bypass
-Partial TLP Bypass
-Normal
If "Normal" is selected, a new tab appears with options to configure "CXL DVSEC Settings", "Device ID", "Vendor ID", capabilities, etc.
Can you clarify what the difference is between these 3 modes, and also if the above listed features under "Normal" are operational?
Thank you,
Ricardo.
