RicardoC
3 years agoCXL IP DVSEC
Is the PCIe DVSEC registers for CXL Device implemented either in the R-Tile CXL HIP or in the Soft Wrapper? If not, is there an Intel IP that can be attached to the CXL.IO port that can provide...
JohnT_Altera
3 years agoHi Ricardo,
If you are refering to CXL Type 3 implementation then the DVSEC will be fully soft-logic.
- RicardoC3 years ago
Hi John,
Thanks for the information, but it seems that you are still referring to the Design Example. We would like to use the CXL IP for our own project and I would like to know if the DVSEC is implemented in the IP provided by Intel or if this has to be developed by customers.
Thank you,
Ricardo.
