Raj_G
3 years agoCXL Example Design simulation: Illegal combination of drivers
Running the simulation of the CXL Example Design, following the CXL_Reference_Designs_User_Guide_v1.5.pdf document, gives the following errors during elaboration:
Error-[ICPD_INIT] Illegal co...
JohnT_Altera
3 years agoHi,
So you are seeing the same error even if you are able to echo the UVM environment?
RicardoC
3 years agoHi,
Yes. I saw the error with the echo of UVM environment. The grep command was run on the log file of the simulation. The path in the log file comes from the environment variable.
Ricardo.
