Raj_G
3 years agoCXL Example Design simulation: Illegal combination of drivers
Running the simulation of the CXL Example Design, following the CXL_Reference_Designs_User_Guide_v1.5.pdf document, gives the following errors during elaboration:
Error-[ICPD_INIT] Illegal co...
JohnT_Altera
3 years agoHi,
Can you check if you have the UVM library opn your VCS simulation tools?
RicardoC
3 years agoHi John,
The UVM library was compiled with the testbench and a grep "uvm-1.2" in the log file that I sent shows prints from different UVM files, as well as the $finish that was called from one of them:
[run]$ grep uvm-1.2 sim.log
UVM_INFO /shared/opt/synopsys/vcs/P-2019.06-SP2-6/etc/uvm-1.2/src/base/uvm_root.svh(412) @ 0: reporter [UVM/RELNOTES]
UVM_INFO /shared/opt/synopsys/vcs/P-2019.06-SP2-6/etc/uvm-1.2/src/base/uvm_resource.svh(564) @ 0.000000 ns: reporter [UVM/RESOURCE/ACCESSOR] reads: 0 @ 0.000000 ns writes: 1 @ 0.000000 ns
UVM_INFO /shared/opt/synopsys/vcs/P-2019.06-SP2-6/etc/uvm-1.2/src/base/uvm_report_catcher.svh(705) @ 593702.342ns: reporter [UVM/REPORT/CATCHER]
UVM_INFO /shared/opt/synopsys/vcs/P-2019.06-SP2-6/etc/uvm-1.2/src/base/uvm_report_server.svh(894) @ 593702.342ns: reporter [UVM/REPORT/SERVER]
$finish called from file "/shared/opt/synopsys/vcs/P-2019.06-SP2-6/etc/uvm-1.2/src/base/uvm_root.svh", line 613.
[run]$ echo $UVM_HOME
[run]$ file /shared/opt/synopsys/vcs/P-2019.06-SP2-6/etc/uvm-1.2/src/base/uvm_root.svh
/shared/opt/synopsys/vcs/P-2019.06-SP2-6/etc/uvm-1.2/src/base/uvm_root.svh: C++ source, ASCII text
[run]$
Thank you,
Ricardo.
