Raj_G
3 years agoCXL Example Design simulation: Illegal combination of drivers
Running the simulation of the CXL Example Design, following the CXL_Reference_Designs_User_Guide_v1.5.pdf document, gives the following errors during elaboration:
Error-[ICPD_INIT] Illegal co...
RicardoC
3 years agoHi John,
I downgraded the version of Verdi to 2019, as show in your elaboration log file, and this allowed the code to be compiled with the -kdb option enabled. The simulation runs longer than before, but it fails with:
UVM_ERROR /fpga/P-2019.06-SP2-6/cxltyp3ddr_tb_22p4/tb/tests/cxl_base_test_eot_checks.svhp(43) @ 593702.342ns: uvm_test_top [CXL_REPORT] CFG_CORERRSTS is 0x4001
I've attached the complete simulation log file for your reference.
Any recommendations?
Thank you,
Ricardo.
