Raj_G
3 years agoCXL Example Design simulation: Illegal combination of drivers
Running the simulation of the CXL Example Design, following the CXL_Reference_Designs_User_Guide_v1.5.pdf document, gives the following errors during elaboration:
Error-[ICPD_INIT] Illegal co...
JohnT_Altera
3 years agoHi,
From the error it looks like it is not able to link Quartus IP library. Can you check your environment to see if the "QUARTUS_INSTALL_DIR" and "QUARTUS_LIB_DIR" is set correctly? Or do you have the Quartus license setup correctly?
RicardoC
3 years agoHi John,
QUARTUS_INSTALL_DIR and QUARTUS_LIB_DIR are set to Quartus' installation path from root:
$ set | grep QUARTUS
QUARTUS_INSTALL_DIR=/shared/opt/intel/intelFPGA_pro/22.4/quartus
QUARTUS_LIB_DIR=/shared/opt/intel/intelFPGA_pro/22.4/quartus
If I modify from these values, vcs_sim.sh fails in the compilation phase, as it cannot find the source files to compile.
LM_LICENSE_FILE is pointing to:
$ set | grep LM
LM_LICENSE_FILE=4071@licmgr:27020@licmgr:/shared/opt/intel/licenses/LR-107633_License.dat
4071@licmgr is for Avery, 27020@licmgr is for VCS and Verdi, and LR-107633_License.dat is for Quartus.
Any other suggestion?
Thank you,
Ricardo.
