CXL Example Design simulation: Illegal combination of drivers
Hi Ricardo,
Can you try based on V1.7 user guide (https://cdrdv2.intel.com/v1/dl/getContent/763513?explicitVersion=true&wapkw=cxl)? If you are still seeing issue, can you provide me the error message?
- RicardoC3 years ago
Hi John,
I still see the same issues using version 1.7 of the document. However, I'd like to point out that I modified some files to dump waveforms using VPD (APCI_DUMP_VPD), instead of FSDB (APCI_DUMP_FSDB), since we don't currently have Verdi. I'm not sure this is the reason why I'm getting the "Error-[ICPD_INIT] Illegal combination of drivers" messages.
I'm attaching the log files for your reference.
In case the lack of Verdi was the reason behind the elaboration failure, would there be anything that I could do to simulate without it?
Thank you,
Ricardo.
