13 years agoCVO won't change resolution
Hi, i have 2 fpga with 2 video systems implemented with VIP cores.
The first fpga can output DVI with 1024x768 pixels or 768x576 pixels these configuration are obtained through the following configuration: Configurable scaler --> CVO the CVO core is controlled by a control synchronizer core, when i want to change the format resolution, i change the scaler output and i change the video mode of the CVO throught the control synchronizer. In the other FPGA, the CVI detects the resolution change and i manage data properly. When i pass from 1024x768 to 768x576 i have no problem, when i try to do the inverse, so from 768x576 to 1024x768, the CVI registers see 768x858. From this bad configuration i can return to 768x576. Where can be the problem?No RepliesBe the first to reply
