ss's avatar
ss
5 years ago
CVO simulation configuration
I have a simple system consisting of a TPG and CVO. When I use the NTSC preset the CVO simulates fine. I added a MM BFM and load the CVO configuration registers. The video output of the CVO never starts up. Any suggestions? The BFM is working to configure the TPG.
  • CheepinC_altera's avatar
    CheepinC_altera
    I believe Sherman has helped to feedback to you on the workaround to use Q20.3Pro. I will set this case to close and we shall continue to follow up in IPS if there is any further inquiries.
    Thank you very much.
