MADesigner
6 years agoCustom transceiver PCS/PMA interface width?
I currently have a Cyclone 10 GX and I was testing the XCVR_NativePhy IP and the XCVR_ATXPLL IP. I succeeded in setting up a Basic (Enhanced PCS) transceiver at 10400 Mbps with a 64 bit wide PCS/PMA ...
MADesigner
6 years agoThank you very much for taking the time to help me understand all this, this is my first foray into multi-gigabit transceivers.
There is one thing I am still confused on if you don't mind explaining or at least pointing me in the right direction so I can learn about it.
If I wasn't trying to allocate every possible bit (5 frames of 20 parallel bits at 500MHz for a 10GHz serial stream of 100 bits every 10nS), what does the transceiver do if I were only sending 2 frames of 20 bits? How do I choose what frequency to clock the 20 parallel lines into the transceiver at? What does the transmitted signal look like in between frames?
Thank you,
Mark
