MADesigner
6 years agoCustom transceiver PCS/PMA interface width?
I currently have a Cyclone 10 GX and I was testing the XCVR_NativePhy IP and the XCVR_ATXPLL IP. I succeeded in setting up a Basic (Enhanced PCS) transceiver at 10400 Mbps with a 64 bit wide PCS/PMA ...
Deshi_Intel
6 years agoHi,
Yup, you got it right. It will take 5 times longer to sample all 100 bits.
Are you building custom protocol or follow some industry standard protocol.
Industry standard protocol typically has fixed the transceiver data rate so user can't simply boost the data rate
dlim
