14 years agocustom Nios bootloader
Hello, I have a very small board containing ethernet phy, sdram and cyclone III fpga only. The fpga upload is done from another board, which has microcontroller on it, using passive serial mode. T...
14 years agoHm, I've set all the vectors to on_chip ram except the exception one. Just a minute ago, I've managed to run the bootloader using SPI status register polling. Now I'll try to use interrupts if possible.
