16 years ago
Custom Avalon-MM salve IP
Dear all
I have an IS61WV25616BLL device on board and want to add a custom Avalon-MM salve IP to be able to use the ram.
Here is my custom verilog code.but when I run the small memory test. It fails can you suggest me what is the problem.
// sram_controller.v
// This file was auto-generated as a prototype implementation of a module
// created in component editor. It ties off all outputs to ground and
// ignores all inputs. It needs to be edited to make it do something
// useful.
// This file will not be automatically regenerated. You should check it in
// to your version control system if you want to keep it.
module sram (
//avalon data bus
input wire clk, // clock.clk
input wire [17:0] avs_s0_address, // s0.address
input wire avs_s0_read_n, // .read_n
output wire [15:0] avs_s0_readdata, // .readdata
input wire avs_s0_write_n, // .write_n
input wire [15:0] avs_s0_writedata, // .writedata
input wire avs_s0_chipselect_n, // .chipselect_n
input wire [1:0] avs_s0_byteenable_n, // .byteenable_n
//sram data bus
inout wire [15:0] sram_data, // sram_data.export
output wire [17:0] sram_address, // sram_address.export
output wire sram_ncs, // sram_ncs.export
output wire sram_nwe, // sram_nwe.export
output wire sram_noe, // sram_noe.export
output wire [1:0] sram_byteenable_n // sram_byteenable_n.export
assign sram_data = avs_s0_write_n ? avs_s0_writedata : 16'bz;
assign avs_s0_readdata = sram_data;
assign sram_address = avs_s0_address;
assign sram_ncs = avs_s0_chipselect_n;
assign sram_nwe = avs_s0_write_n;
assign sram_noe = avs_s0_read_n;
assign sram_byteenable_n = avs_s0_byteenable_n;
// TODO: Auto-generated HDL template
endmodule
