12 years ago
Critical Warning (10169) on DDR2 ALTERA IP
I'm using Altera's DDR2 IP to control DDR2 memory. 2 critical warnings as below pops out after compilation. The warnings are pointing to the code that ALTERA provided for DDR2 control.
I don't konw why these 2 warnings pop up with "critical level". Should I do something to resolve these warnings and how? or just leave them as it is?
(The attachment is my project files)
--- Quote Start ---
Critical Warning (10169): Verilog HDL warning at alt_mem_ddrx_controller.v(508): the port and data declarations for array port "afi_rrank" do not specify the same range for each dimension
Critical Warning (10169): Verilog HDL warning at alt_mem_ddrx_controller.v(509): the port and data declarations for array port "afi_wrank" do not specify the same range for each dimension
--- Quote End ---
1 Reply
