17 years agoConverting Quartus 6.0 component to 7.2+
Hello:
In Quartus 6.0sp1, I created a relatively simple Avalon Master interface for an external processor. Using Component Editor to create the new component, I added an Interface (Avalon Master) and added the 8-10 signals (address, data, etc etc) needed by the Top Level to connect into the SOPC system. My external processor connected through this component into the system defined by SOPC. Now I need to go back and add some new features & (naively?) attempted to update to 7.2. Component Editor doesn't work the same way though. What's the closest approximation to the component I had created previously? The Conduit interface might be it, but I haven't found sufficient documentation to make sure. Or am I missing the point entirely? Any help is GREATLY appreciated! Thanks in advance! Kevin.4 Replies
Use a conduit interface for any signals you need to export out of the SOPC system. For the avalon master, use an avalon memory-mapped master interface.
Jake - Altera_Forum
Thanks for the reply!
How will I tell the system how to connect the conduit/exported signals to the appropriate Avalon Master signals. I believe that requires HDL code, correct? Again, thanks for the help! Kevin. - Altera_Forum
Okay. Well you really have two options.
1 - You write HDL code that does the conversion from the Avalon to whatever bus structure your external processor uses. Then yes you use a conduit to export whatever signals you need. 2 - You don't provide HDL code. Create an Avalon Memory-Mapped master port and the signals will be automatically be exported for you. This is the same as in 6.0. If your component is not HDL-based, all signals will be exported. Jake - Altera_Forum
Option# 2 doesn't work exactly the same...the 7.2 Avalon Master only provides the split versions of data (readdata & writedata). The 6.0 version had those options and the bidirectional data type. Also the outputenable type is missing.
Thanks for the reply....looks like I'm off to HDL!
