SimonRichter
5 years agoControlling output files when generating IP from the command line
as part of automated verification I'm having my Continuous Integration server rebuild the IP blocks to check that these can indeed be rebuilt without error and no outdated files went into an im...
AdzimZM_Altera
5 years agoHi Simon,
For your situation, I encourage you to use the qsys-generate or ip-generate utilities in order to generate the files.
I have shared the link below for some guides of the the use of the qsys command line.
You can also check the link below in chapter 7 for more detail.
You also can use --help option to display some help regarding to your utilities such as qsys-generate --help
I hope you this can help you to get your required files.
Adzim
