15 years agoConsolidate bugs of PCIe examples
Hi, I'm playing around with PCIe on Arria II. As you know, in order to use PCIe, you need a lot of "supporting" logics, such as computing the available credit, arbitration between multiple DMA...
15 years agoAnother bug,
--- Quote Start --- - in the file altpcierd_rxtx_downstream_intf.v - the logic that controls the signal tx_busy tx_busy is asserted too late. It is asserted on the 2nd cycle after arbitration is granted and data is valid for transmission. The error occurs when the PCIe tx_stream_ready is de-asserted right in the middle cycle after ARBITRATION is granted and TX_BUSY is asserted, the whole state machine gets stuck. See picture, the tx_sel_pcnt is the abitration grant signal, it is deasserted right after the statemachine sees that it is granted access. The state-machine is stuck there wait for acknowledgement from the PCIe core. http://www.alteraforum.com/forum/attachment.php?attachmentid=3177&stc=1&d=1287051603 --- Quote End ---
