connection_between_msgdma_and_OCM
Hi
I will be taking over this case from Eber.
Sorry for the late reply.
There is an example for connection between the MSGDMA to OCM in the example below:
Agilex™ 7 FPGA - Nios® V/m Processor with DDR DMA and OCM Design Example (intel.com)
Jingyang, Teh
- SERMASWATHIKA2 years ago
Contributor
Thanks for your response i will check that.
i want to confirm that sgdma support is there or not.
why bsp is generating mSGDMA library files in firmware even FPGA qsys design contains sgdma ip (sopcinfo).
We faced this issue. after that only we moved to msgdma ip use.
Whether we are moving in right direction. Please confirm this.
Contributor
Hi ,
Thanks for sharing the reference design.
Can you share the reference design which has ethernet interface using msgdma and ocm ? we are trying to implement the TSE with msgdma
