13 years agoConfigure the Alpha Blending Mixer
Hi, When I debug the Alpha Blending Mixer, it is failed. Software:Quartusii 12.0 +Nios II Eclipe Project: Test Pattern Generator0 ----> |-- Alp...
13 years agoHi,guys
I find the root cause: the background is not the 1st layer:-P you don't need to congfigue the background,because it is on default. mixer.set_layer_position(0, 150, 0);//the 1st layer mixer.set_layer_enabled(0,true); mixer.set_layer_position(1, 600, 0);//the 2nd layer mixer.set_layer_enabled(1,true); ---there are 3 layers. Thanks!:D
