13 years agoclocked video output underflow and display flickers
Hi I'm doing a qsys design which is composed of a sdi rx, a clocked video input, a deinterlacer, an interlacer, a clocked video output, and a sdi tx. This design simply receives an interlace...
13 years agoHi Socrates
Thank you for the reply. You really help me a lot on my SDI project. I'm wondering how I can check whether the sdi reception clock is inaccurate. Because I generate the sdi input video by the rtl code provided in Altera SDI example, I doubt that the timing of the sdi input may not be very accurate. This generated sdi input video can be received by SDI receiver. I can see frame locked by checking rx_status. But I'm not sure about if the input video is very accurate. About the Genlock, I'm confused. Is Genlock a technique which can be done in SDI IP or an additional chip on PCB? I may need more time to study Genlock. Thanks again.
